How does labview detect end of file?
Hello!
My question is how labview detects the end of file at the Read from Spreadsheet File VI.  What I would like to do is basically to read from a  text file a number of numeric values and afterwards build an array containing these values. Till now I have made a vi that uses the aforementioned vi and put it in a while loop that its conditional terminal is connected to the EOF? but it never stops. Could you please suggest a solution to my problem? (I have already seen a similar question in this forum but the answers didn't help me..) The VI along with an example file to read are attached.
Thank you very much
(3,725 Views)
Please take off the while loop. and directly connect the indicator to the all rows output of the VI.
That will give you a 2D array of whatever is there in the spreadsheet.
Hope this helps.
(3,716 Views)
Can you please save the VI in LV8.5 or earlier format?
(3,711 Views)
It helps! Thanks a lot!
(3,706 Views)
