How does a CIN code works in LabVIEW?
hi..can any one explain as to how a CIN code (written in c/c++) works in LabVIEW.Do we have to import the c/c++ file too when we import the respective VI? How does the CIN code work in an exe file without having to load the C/C++ code?
(2,675 Views)
When you create the VI that calls the CIN you load the binary object code into the code interface node itself and it's stored as part of the VI. Hence you don't need to include anything special in your build. Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,675 Views)
