How do you use custome icons with listbox
I have been trying to add a custom sysmbol to a listbox.  I have folled the Tree Image VI example but have not had any luck.
I saw a post on this board that says to use a picture ring turned into a constant.  I am assuming that the picture ring constant is to be wired into the itemsymbol property.
I have had no luck making a picture ring constant that can be used in the same manner as the listbox icon constant ring found on the numeric pallete.
Any help on this would be appreciated.
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
Message 1 of 11
(8,099 Views)
Okay I stumbled onto the answer
Making the symbol
1.  use a read function (BMP, JPG, PNG) to send a image to a picture control,  Front panel pallete Graph - Controls - Picture
2. once you have ran the VI once and populated the picture control goto the block diagram and right click the picture control and
create a constant.  Repeat for each sysmbol you wish to make.
Using the symbol
3.  Wire the picture constant to a picture to pixmap vi
4.  Create a Invoke Node Method for the listbox - Custom Item Symbol -  Set To Custom Symbol
5.  Wire the Lisbox Symbol Ring Constant to the Index of the Method  (this is found on the ndialog and user interface funnction pallete)
6.  Select the standard symbol you wish to replace with the custom symbol  OR wire a numeric constant of 41 or higher to add the symbol
to the symbol array.
7.  Create a listbox symbol visible property and wire a T constant to enable sysmbols to be visible
8.  Create a propert Item Symbols and select the item (row index) and enter the index of the symbol array to be used.
if your not using custom symbols this is were the Listbox Symbol Ring Constant is typically wired.
Message 2 of 11
(8,094 Views)
Broken VI , trying to compare string value to set symbols
Any Help would be appreciated
Message 3 of 11
(8,065 Views)
Tim,
The "ItemSys" property node of the listbox expects an array of integers corresponding to the symbol to use for each item in the listbox.  In order to set a symbol for each entry programatically you will want to move the property node out of your for loop and pass it an indexed array after the loop has completed.
See the attached screenshot for an example (which assumes the symbol for case "S&P" is the 41st symbol in the symbol list).
Hope this helps,
Simon H
Message 4 of 11
(8,053 Views)
Update to allow reading of BMP files to show the idea of reading the BMP file then creating th econstant.
Best regards
Tim C.
Message 5 of 11
(7,711 Views)
Can you make the picture in the listbox larger?
Message 6 of 11
(6,998 Views)
Hallo!
Is it possible in a listbox to have the symbol in the right side of the item names (in your example the symbol is in the left side)
Thank you so much
monica
Message 7 of 11
(4,856 Views)
Hi Monica,
no, listbox symbols are shown at the left side of the listbox item…
Message 8 of 11
(4,848 Views)
Hi GerdW,
thank you very much for your answer.
Please can you suggest me a work around or a different indicator type to have names on the left side and symbols on the right side?
I would like to have something like the attached file (done by paint) in my user interface
thanks
Message 9 of 11
(4,844 Views)
Hi Monica,
Use a 2D picture indicator and draw anything you like to show the way you like it…
Message 10 of 11
(4,842 Views)
