How do you time stamp trigger and gate data
I have labview 7, windows xp, pxi6070e, scb-68,PXI-1042 NI-Daq system.
I am using the trigger and gate function to capture events with the start trigger threshold with a pre-data measurement (5 samples) and post datameasurement (5 samples).
The signal input is a 0.25hz (4 second period) signal with a 25% duty cycle. For 75% of the time, the signal is low at 0 volts. For 25% of the time, the signal is high at 1 volt.
My trigger is set on the rising edge with a threshold of 0.5V. As my trigger detects a high, it outputs data to a .lvm write file in increments of rising integers for example (1, 2, 3, 4 ....) instead of the real time of (0, 4, 8, 12, ...) seconds. Is there a way to overcome the increment function of th
e trigger and gate function or assign a time stamp to each triggered occurance? That way my triggered responses will have the time instead of increments in the .lvm file?
(3,306 Views)
If I understand what you are wanting to do, I think the answer is no. There is no way for the hardware to give you that information. It would have to be a software function in order to convert the number of increments into the number of seconds before you write it to the file.
Hope this helps,
Steven
(3,306 Views)
Steven,
The trigger and gate in labview seven has pre/post samples that when tripped is sent to a file with the wrong date and time. In fact, the triggered signal is incremented with the external PFIO trigger system clock. I have it set at 4 seconds with a duty cycle of 25% high, 75% low. So if 20 seconds passes, the trigger and gate function will count 5 times whether a trigger occurred or not. I will get a number that is not associated with the time and date of the occurrance.
To overcome this, I got the computer clock time, formatted it to the style I wanted and then wrote it into the comments portion of the .lvm file. I also used the data valid function of the Trigger and Gate to write to the .lvm file only at specific triggered times.
This approach worked for a single trigger during the occurance. It works partially if there are multiple triggers during the time period.
The time period that I was interested in is the 25% high or 1 second. I would received multiple triggers during the 1 second from time to time. The time that was written for first trigger was correct. The second or third trigger time was incorrect, second trigger being 4 seconds later, third trigger being 8 seconds later (updated with the system clock). Haven't found a way to overcome this yet, will do later.
Derek
(3,306 Views)
