How do you set the "user defined" parameters
Message 1 of 9
(4,424 Views)
You forgot to add any text to your post. 😮
Please add a few more sentences and explain your definition of "user defined" parameters.
Do you want to read initial control values from an ini file, for example?
Message 2 of 9
(4,418 Views)
Jim
Message 3 of 9
(4,399 Views)
Jim
Nice way of replying........
Message 4 of 9
(4,382 Views)
How do you set "User-Defined" parameters in VI Analizer
Message 5 of 9
(4,349 Views)
Where do you see this?  Can you show a screen shot of VI analyzer showing "user defined" parameters?
Message 6 of 9
(4,343 Views)
This is a line from analizer results
Coercion Dots    This diagram contains 26 coercion dots, which is more than the user-specified maximum (10).
 the question is how dose the user specify the maximum.
Message 7 of 9
(4,338 Views)
See attached.
Message 8 of 9
(4,331 Views)
When you select which tests to run, expand Block Diagram>Performance>Coercion Dots. Change to whatever value you want.
If you had properly formatted your question correctly in the first place with details in the message body instead of just an amibiguous topic and then juest repeated that when asked for more information, you would have gotten your question answered a long time and not wasted the time of som many people.
Actually, with just a little clicking around or using the Help, you could have found this yourself.
Message 9 of 9
(4,330 Views)
