How do you read a cluster over DataSocket with C?
Hello All,
I am new to Labview and DataSocket in particular, so any help would be greatly appreciated.
I am trying to write a data viewer program in IGOR (www.wavemetrics.com) which will receive multi channel data being published to a DataSocket server and display the requested channel real time. In order to do this I had to write a dll in C, then import that into IGOR, which allowed me to access all the functions in dataskt.dll (DataSocket Library - NI LabWindows™/CVI™ 9.0 Help ).
I have successfully compiled this dll with the DS_Open, DS_IsConnected, DS_DiscardObjHandle, DS_GetDataValue functions and tested them by publishing and retrieving a type double from the server. The problem I am having is that the real data is published as a custom cluster of a double, two singles, and a 1D array of singles (the datapoints at that time slice).
The second input of the DS_GetDataValue function is an unsigned int which represents the type of data expected from the server. There is a list of acceptable data types is in cviauto.h, but as you can see none of them are for a cluster (or structure for that matter):
/* Use these to specify the type of a function parameter, function return */
/* value, and a property. */
enum {
CAVT_EMPTY = 100,
CAVT_NULL,
CAVT_SHORT,
CAVT_LONG,
CAVT_INT = CAVT_LONG,
CAVT_FLOAT,
CAVT_DOUBLE,
CAVT_CY,
CAVT_DATE,
CAVT_BSTR,
CAVT_DISPATCH,
CAVT_ERROR,
CAVT_BOOL,
CAVT_VARIANT,
CAVT_UNKNOWN,
CAVT_UCHAR,
CAVT_CSTRING, /* null terminated ansi (multi-byte) string */
CAVT_OBJHANDLE,
CAVT_CHAR,
CAVT_USHORT,
CAVT_ULONG,
CAVT_UINT,
CAVT_LONGLONG,
CAVT_ULONGLONG,
CAVT_BASICTYPE_MASK = 0x0fff,
CAVT_MODIFIER_MASK = 0xf000,
CAVT_ARRAY = 0x1000,
CAVT_BYREF = 0x2000,
CAVT_IN = 0x4000,
CAVT_OUT = 0x8000,
CAVT_AUTO_CLEAR = 0x0800 /* valid only for VARIANT arguments. VariantClear is called on the variant after the function call */
Then the third input is a pointer to a variable that is the same data type. I have created a structure to match the cluster and tried to pass that but it does not change the values of the structure.
Another thing I have tried is the DS_GetDataType function, but that returns 100 which corresponds to CAVT_EMPTY.
Is there any way to define one of these for a cluster? Is there a better way to do what I am trying to do? Any help would be appreciated.
-Jeff VT
(4,073 Views)
I think you would be better off breaking the structure into each field rather than trying to pass the info through as a cluster.  Is that possible?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(4,057 Views)
Thanks for the response.
Unfortunately I do not have control over how the data is published to the server.  There are actually several clusters like I have described, each with data for a particular location during the test, all being published to the same server.  The data recording program that we have is written to accept the cluster (it is a labview program) so we don't want to change the way it is published right now.  Also we are dealing with a couple hundred datapoints in the array for each cluster.
-Jeff VT
(4,050 Views)
I see.  I wasn't sure based on your original description.  Let me think about it and see what I can come up with.
-Matt Bradley
(4,047 Views)
hi,
i have the same problem, did you find any solutions for it? thanks.
(3,856 Views)
Clusters are coded as structures in C. To pass a structure over a datasocket you will want to cast it as a variant data type. In CVI you will be able to find functions for passing values to variants and retrieving values from variants.
Take care!
Tanya
Tanya Visser
LabVIEW Group Manager
(3,814 Views)
