How do you pass a Visa Resource Name to LV Created DLL
Hello and thank you for reading.
Here's my problem: I have to create a DLL for a customer who wants to use the LV code I developed in thier software. I am using an FTDI chip as a virtual COM port through the visa drivers. I created a test.vi that takes reads a serial value. The only problem is that I need to be able to pass the com port to the dll and I don't know how to do this.
The function prototype when I build the DLL (or shared library in LV) is as follows:
int32_t __cdecl READX(uintptr_t *VISAResourceName2);
Can someone help me understand the proper way to do this? I don't know how to get the information for the uintptr_t *VISAResourceName2.
Thanks!
Joshua
(2,916 Views)
Joshua
Are you putting your Com Port on the Front Panel as a Control and wiring it to the connector pane? Are you saving the VI before trying to create the DLL?
Kira T
(2,899 Views)
Kira,
   Yes, it is all connected correctly. The problem was that I didn't know how to deal with VISA resource data type when it creates the DLL. So I created code in LV that took an int and combined it with a "COM" string and coerced it to a visa resource just by wiring the string the the visa resource port. I am not crazy about coercing variables and hate the red dot so I type casted it from a string to a visa resource in LV. Thay way in C++ I could just pass the port number and have LV DLL take care of the typecasting.
Joshua
(2,883 Views)
