How do you modify the appearance of a control
I want to add a red arc on the outer edge of a meter control.  The arc should only cover about 120 degrees.  Is there a way to modify the graphics of a control?
Thanks in advance.
(2,601 Views)
Yes. It's discussed in the manual.
You can also peruse this example: Customizing the Gauge Control in LabVIEW.
If you search you'll find lots more information.
(2,589 Views)
