How do you get volume names in Labview 7.0/Windows XP?
I've seen the post on how to get the drive letters using the "List.vi" with a blank path. I've also seen the example code using the windows API to get the volume information, but the "name" does not return in Labview 7.0 Windows XP. Is there a simple way to get the names of the drives attached to the computer?
Thanks.
(3,581 Views)
Here is a vi that returns the volume name and serial number of drive c. You can modify it to get names of other drives by modifying the command line to System Exec.
- tbob
Inventor of the WORM Global
(3,576 Views)
how to get information about the RAMDISK( RAM converted to hard disk) using this VI?
I am not able to find command for it.
(3,093 Views)
The suggestions above don't work?  I would've expected it to look just like any other drive, because that's what it's emulating.  That brings up an interesting question that I've never explored before.  What about other kinds of virtual drives?  Would it, for example, show a substituted drive?  Hmmm... very interesting!
Bill
CLD
(Mid-Level minion.)
(3,080 Views)
