How do you get the sum of even numbers from a 1D array
another way (without multiplication)
Message 11 of 19
(2,951 Views)
Qute! Here's what I had in mind.
Message 12 of 19
(2,928 Views)
This is what I had in mind.
Ben64
Message 13 of 19
(2,905 Views)
my way is faster (large array)  Smiley Wink  Smiley Tongue
Message 14 of 19
(2,896 Views)
Yup, I arrived at the same code in the end.... 😄
Message 15 of 19
(2,874 Views)
Thank you everyone for your hep. I have been able to get it done.
Spoiler
Message 16 of 19
(2,795 Views)
your code need some change
you have to add this at then end -1*( your last value -maximum number of array+1) /2
Message 17 of 19
(2,784 Views)
There are quite a few code examples above. You need to be more specific. Ideally quote the post you are replying to.
Why don't you show us some LabVIEW code instead?
Why would the last value matter? The sum does not depend on the order of elements.
The maximum number in the array is also irrelevant. Even if the max is 9999999, the sum will be zero if there are no even numbers.
Message 18 of 19
(2,774 Views)
Dear
Message 19 of 19
(2,737 Views)
