How do you create a cluster in C# for use in a .NET assembly?
I am working on aproject that has a multi-disciplinary software development team.  My specialtyis LabVIEW, and I am trying to use a .NET assembly created in C#.  I havebeen able to access most of the constructors so far.  However, thisassembly will be used to feed data to my VI that will be displayed every timenew processed data is available.  I am going to need that data in the formof a Cluster.  How is a clusterimplemented in C# for use in the assembly?
(3,984 Views)
The way to pass a cluster to and from your C# code is to use a Struct.
(3,956 Views)
Matt,
Here is a great reference for using structures. Let me know if this helps!
http://www.vbdotnetheaven.com/UploadFile/rajeshvs/StructuresInVbDotNet04192005235119PM/StructuresInV...
(3,937 Views)
