08-11-2005 05:19 PM
08-11-2005 08:16 PM
08-12-2005 09:23 AM
08-15-2005 02:59 PM
rgehmlich,
I think the reason you're having trouble getting the timestamp to start at 0 is because the acquisition and the Get Date/Time in Seconds.vi are not happening at the same time. I think the system time is being read at the start of the program, and then the code goes through creating or opening the file, setting up the task, and doing the acquisition and all this probably takes between 1 and 5 seconds (with selecting the file to be opened). What I think would work better is to take the time information of the first waveform from the first iteration of the while loop and subtract that value instead of the Get Date/Time in Seconds value. I've modified your code to do this (and I took out the daq code and replaced it with an express VI since I don't have a daq card in my computer right now) and the timestamps start at 0 for me. Take a look and see if it helps.
Tyler S.
08-15-2005 04:13 PM
