How do you activate a document programmatically?
I would like to open a MSWord document (or any document for that matter), within LabView while the program is executing, to allow the user access to updated information concerning the setup or procedure for a particular test the operator may be performing.  I have created an ActiveX container referencing the document and am able to open/edit while LabView is stopped, but ideally, I would like to open the document programmatically, via command button, for example.
Can someone point me in the right direction?  Thanks.
(2,911 Views)
It's hard to tell without seeing your code or knowing more about the architecture you are using.  For starters,  a quick and simple structure is to have the control which will open the  document handled by an event structure which is in a while loop.  For further advice, you should post your code if possible.
(2,894 Views)
I recently posted a VI on the LAVA forums that is a Dialog box consisting of an Internet Explorer ActiveX compoenent and some OK / Cancel buttons.
You can load any type of IE compatible file (including .DOC, HTM, JPG, GIF, etc) or a URL. You can also open PDFs or AutoCAD DXF and DWGs if you install the appropriate plugin.
See this LAVA post...
IE_HTML_Dialog.vi
(2,873 Views)
