How do you Write to Access Form Controls from labVIEW using Active X?
I'm trying to interface with MS Access by reading from and writing to controls in a Form. Reading the data into LabVIEW is easy...using the Controls Active X class and the Item method. But since this Item method is read-only, I am trying to come up with a way to write Text data back to the controls. Any advice would be greatly appreciated.
(2,932 Views)
Sorry if this is so obvious, but, did you right click on the property/invoke node and select change to write? It works for Excel and many activeX i found.
Good luck
(2,932 Views)
