How do update mySQL table's data with LabView database tookit ?
Dear all ,
thanks .
(9,295 Views)
"ase" <x@no.email> wrote in message
news:1222018814602-780413@exchange.ni.com...
> Dear all ,How do update mySQL table's data with LabView database tookit
?thanks .
Use an UPDATE statement.
(9,272 Views)
Hi Wiebe@CAR…
yes ,you're right .
Use update statement.but I don't know how to carry out it with labview .
could you give a example ?
thank you inadvance .
(9,261 Views)
I don't have the toolkit installed, but there should be examples shipped
with it.
If you know how to send an INSERT statement, just replace it with an UPDATE
statement.
Wiebe.
(9,248 Views)
This is the functino I use to update.  You need to open a connection with the open connection function. Reference it with the name of a driver you create in ODBC sources found in control panel/administrative tools.  Pass in the table you want to update.  Then an array of columns you want to update and what value you want to be in that column.  In the condition you must specify what entry to update (example:  WHERE [Money] = '6')  This would update the value of the specified column where the money column equals six.  Checkout the microsoft developers network for more about SQL conditional statements. Be sure to close the connection with the close connection function when you've finshed your statement.  Good luck
(9,242 Views)
Hi
just stumbled over a vi in the toolkit lvlib.
There is an "DB Tools Update Data.vi" that works more or less like the Insert vi. It is not part of the DB menue, so you'll have to select it with the general "Select a vi...".
Like the Insert it has the advantage of handling clusters as a variant.
Good luck, Gabi
7.1 -- 2013
CLA
(8,901 Views)
I generally build a statement through normal string concatenation and do a Execute SQL Query.
(Ofc you first need to open database, and afterwards free the query and close the database (atleast when you leave the program))
/Y
Qestit Systems
Certified-LabVIEW-Developer
(8,886 Views)
