How do i plot a graph after se;ecting a cell in an array
Hi
I want to select a cell and then plot a single graph?
Thank you.
(2,791 Views)
Hi Adrian. Your question isn't clear enough. Which data do you want to use to plot the graph?
___________________
Try to take over the world!
(2,777 Views)
___________________
(2,776 Views)
Hi
In my array,I have values. Each of those values has two graphs associated with it. I was wondering how to plot these graphs while selecting a cell?
Thank you.
(2,764 Views)
If you want to get the data you should use the Index Array or Array Subset functions.
If you want to know what your selection is, create a property node for the array and use the Selection start and Selection size properties and wire this data into the Array subset VI.
___________________
(2,753 Views)
