How do i match multiple characters (including new line characters) in the "after match" portion of a "match regular expression" function?
Hello LabVIEW community!
I am constructing a VI that will parse text and i am aware of regular expressions. My text (which is on the front panel and NOT in an array) looks something like this:
calibration.cvs
-rw-r--r--    1 root     root        70096 Jun 30  2009 calibration.xml
-rw-r--r--    1 root     root        70099 Jun 30  2009 calibration.xml.bak
With my VI, i was only able to delete everything in front of calibration on the first line.  I have been trying to apply this technique all at once to the entire text but nothing seems to work. Attached is what my VI looks like.  I appreciate any knowledge and assistance you may be able to give to me.  Thank You!
Message 2 of 12
(4,743 Views)
What is the desired output?
Lynn
Message 3 of 12
(4,739 Views)
Hello Lynn,
the following is my desired output:
calibration.cvs
calibration.xml.
calibration.xml.bak
As listed above, I was able to output the calibration.cvs just fine, but I can not figure out how to get the other ones to do the same.
Message 4 of 12
(4,730 Views)
Sorry, Magnus:
Could you post a screenshot of the VI block diagram?  I have an earlier verison of LabVIEW than you.  If you could, I'd appreciate it!
Bill
Bill
CLD
(Mid-Level minion.)
Message 5 of 12
(4,710 Views)
Hello Bill,
I'm a new user to this forum so I am unfamiliar with pasting images on here, so what I did was I pasted my screen in MS Word and then attached it to this thread.  I hope this helps you help me.  Thank you for your assistance Bill.
Message 6 of 12
(4,702 Views)
Similar to jack47, I used two Match Pattern function in a loop.
Lynn
Message 8 of 12
(4,681 Views)
Magnus42 wrote:
Hello Bill,
No problem, thanks for posting the pic; everyone here is obviously on the ball because there are some cool solutions for you.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 12
(4,674 Views)
