How do i get my waveform graph to plot all points that are sent to it in sequence and not just the latest point?
I am fairly sure that you can simplify your read for the keithly stuff. You should be able to make that one read. I do not have the keithly vi's so I can not tell you that for sure. I would expect that you should be able to make it read all three channels with one set of vi's and just restart the read if you change the channel cound. You will have to get someone with the keithly vi's to help optimize that part of your code.
I would also suggest that you start looking at the producer consumer systems that are provided by NI in the example file. You can set one loop up to do the data acquisition and one to do the data processing and saving. It is much more efficient that way.
Tim
GHSP
Message 21 of 87
(1,369 Views)
Alright, I am having some trouble with the power supply blocks in the take reading state. It is the bottom right corner of the code with the two fromula blocks. Previously I had it working so the amperage would step up as the iterations passed. It is still wired the same way but for some reason tha amperage is stuck at about .145. I am not sure why it is no longer stepping up and down.
Message 23 of 87
(1,365 Views)
I had to hook up the iterator to the formula node since we are no longer using the incrementor on the while loop to get the cycles. This should make it work.
Tim
GHSP
Message 24 of 87
(1,359 Views)
That solution was saved in version 10.0
Message 25 of 87
(1,355 Views)
Sorry it has been busy around here.
Tim
GHSP
Message 26 of 87
(1,352 Views)
Can I ask what the x+1 thing is for in the bottom right hand corner of the take reading state?
Message 27 of 87
(1,349 Views)
I am going to be taking off until Tuesday so if I do not get back to you right away you know why. If you need help right away then you could start a new thread with a new question. I hope that I have been helpful along the way and good luck unitl I get back.
Tim
GHSP
Message 28 of 87
(1,348 Views)
You have been an incredible help Thank You much and have a great Memorial day
Message 29 of 87
(1,346 Views)
That is for counting how many time you have been through the take reading step. That way you can only go through 25 times. If you look on the wait state you will see that we are keeping up with how many times you have taken a reading so that we can stop after 25.
Tim
GHSP
Message 30 of 87
(1,343 Views)
