How do i connect to a remote SQL database
hi,
     How do i connect to a remote SQL database using labview,ODBC and the db connectivity toolset.
Message 1 of 8
(5,386 Views)
1. Set up ODBC to the correct address and make sure Test connection works.
2. Use the configured ODBC name with Open Database.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(5,361 Views)
UDL is best option.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 8
(5,352 Views)
There are step by step instructions right in the manual (below).  Basically you can set up an ODBC connection on your PC and use its name when you open a connection OR you can send a full connection string right to the DB Tools Open Connection VI.  Either way you'll probably need permissions set up by whoever is administering the server (assuming the database is secured).
https://www.ni.com/docs/en-US/bundle/lvdct-api-ref/page/dct_intro.html
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 8
(5,344 Views)
@Ranjeet_Singh wrote:
UDL is best option.
I agree, UDL is better, but that was not the question. 😉
/Y
Qestit Systems
Message 5 of 8
(5,334 Views)
UDL is best option.
/Y
why not? For connecting to remote database, we can use the UDL
--Ranjeet
Message 6 of 8
(5,302 Views)
yes i tried UDL it work .but i may about how to connect through  ODBC.
Message 7 of 8
(5,291 Views)
Yes there are other ways but advantage is whenever required, we can change the connection string. Hence we dont need to hardcode it
--Ranjeet
Message 8 of 8
(5,270 Views)
