How do display current time on axial X?And every data change one time per hour .
Hi all ,
For waveform chart/graph .
for detail , see attach file
Message 1 of 8
(4,456 Views)
Hi acty,
you can try two options:
1) switch the x-scale formatting to 'relative time'
2) initialize your waveform data with correct start time - at the moment it's set to zero and your computer is using timezone GMT+8 Smiley Wink
Message 2 of 8
(4,447 Views)
Message 3 of 8
(4,426 Views)
Message 4 of 8
(4,426 Views)
Thank you in advance !
but how do make interval to be 1 hour for every data ?
Message 5 of 8
(4,424 Views)
It's really simple to use the Elapsed Time function. It has a Boolean output called Time Has Elapsed. Wire this to a case statement and put your data acquisition inside the true case.
Message 6 of 8
(4,408 Views)
Could you give me a sample ?
thank you !
Message 7 of 8
(4,404 Views)
Uh, put the Elapsed Time function on your diagram. Put a case statement on your diagram. Wire the Time Has Elapsed output to the case selector.
Maybe you should spend some time learning the basics of LabVIEW. There are a couple of on-line tutorials at http://www.ni.com/academic/lv_training/how_learn_lv.htm.
Message 8 of 8
(4,393 Views)
