How do I write to file
I am acquirng a continous 4-20mA using DAQmx read. How can I write the data acquired as excel file, can some explain how to use the write labview measure file function, or is there any better way of writing using some DAQmx write?
My acquisition is from 6 channels, so I would like all 6 readings to be written.
Yemi
(2,991 Views)
if you are acquiring "waveforms" arrays you can use the VI "Write waveforms to file".
Bye
CLD - Labview Certified Developer
(2,972 Views)
Also, to find example code, go to "Help" >> "Find example..." and search for "excel" if you want to write data to Excel document or search for "spreadsheet" if you want to write data to tabulated text documents.
Hope this help
Epictetus
Antoine Chalons
(2,969 Views)
