As usual ... therefore do not consider them related. Consider the TAB control like decoration, which helps you to categorize your controls hiding ones when showing others. If you double-click one of those indicators, on the block diagram is like any other indicator you have outside the TAB control.
On generating foreign language versions of a VI, I made all FP objects display their caption instead of the label and then change the caption text on the fly. This works quite well for all sorts of controls, just the texts on the tabs themselves are not accessible. Which brought me to the conviction, that I could not use tab-controls. Or does anybody know where to set the tab-text programmatically ? Gabi
In the diagram, you could create a property node for the tab and select the "pages" option. This is an array of references to each page in the tab control. If you index out eact reference, you have access to the page properties that allow you to change captions, names,....
On Mon, 6 May 2002 16:50:12 -0700 (PDT), VipersView wrote: Why not use a CASE arround the TAB Control ?
>In the diagram, you could create a property node for the tab and >select the "pages" option. This is an array of references to each page >in the tab control. If you index out eact reference, you have access >to the page properties that allow you to change captions, names,....
Alright, I created a property node for the tab control, changed the property to "Pages", used an index array to get one reference and connected this to a property node. The only properties that I get are: Class ID, Owner, Owning VI, Page Enabled State, Page Visible and Controls on Page. So, the question remains: how to change the tab names?
Version 6.0.2. I think that I should start prefacing my messages with what version I'm using. And before I hear ANOTHER tirade about upgrading, I'm not working for a company that has the money to spend.
