How do I use this formula for images?
Hi there!
I'm new to Labview and I don't get on with the following problem.
What I'd like to do is use the following formula with three color bmps
I=sqrt[(I1-I2)^2+(I1-I3)^2+(I2-I3)^2]            I is the resulting intensity, I1,I2,I3 are the intensities from the three images.
At the moment, I use already saved images, later I'd like to get them from a camera (get 1. image, move Piezo; get 2. image, move Piezo...)
I tried to convert the images to arrays and apply the formula to them, but that didn't work.
So how do I do this calculation?
Is there a possibility to pass the images to Matlab? (I use Matlab for the calculation now and its working fine, but I need to automate the whole process)
I hope someone can help ^^
Pandamütze
PS: I use Labview Version 8.6 including LabviewVision
Message Edited by Pandamütze on 08-20-2009 03:01 AM
Message 1 of 10
(4,042 Views)
Did you try math script in labVIEW?
Message 2 of 10
(4,032 Views)
Hm... I tried but there was only the possibility to pass an array to matlab. it would have been nice if i was able to pass the image as it is, because the matlab script works with the images without converting them to arrays.
Message 3 of 10
(4,022 Views)
Yes you need to convert them to array and feed it. (sadly)
Message 4 of 10
(4,017 Views)
Hi pandamütze,
you have 3 images. Are they always the same size?
If so I would get the image content as array, calc the "intensity" for each (you should define "intensity" clearly) and then do the error calculation with standard math without any loops/matlab/mathscript involved...
Message 5 of 10
(3,985 Views)
the images are all of the size 2080x1542
I just read this "The basic data format for an image is a two-dimensional (2D) matrix, where the value of each element (a pixel) is the intensity at a physical location." which means I have to do the calculation for each Pixel.
to get the "conventionel" image (the project is called "Structured illumination"), I use the imageadd to caculate (I1+I2+I3)/3.
Message 6 of 10
(3,961 Views)
Hi pandamütze,
see example for calculation using standard math...
Your description of intensity is still vague. When using 24bit color images you usually get a 32bit value per pixel containing the RGB colors (each 8 bit). This is no intensity! Intensity can be seen as gray level of the pixel, but there are different conversion from RGB to graylevel possible...
Message 7 of 10
(3,940 Views)
Hi!
this is what I came up with ^^ I'm not sure if its working like this, but after all, the result looks a bit better than before
thats what I got CHO3_struk_test.JPG yes, there is something ... ^^
the images I load in look similar, just with stripes on them (the point is to calculate an image from the focal plane by using three images with a projected grid pattern [pattern moved 1/3 of a period between the images])
Message 8 of 10
(3,910 Views)
Accepted by topic author Pandamütze
problem almost solved. I get the right image, just a bit darker than the resulting image of the matlab calculation
I attache my latest VI if someone is interested
thanks to you, thinking about your questins helped a lot ^^
Kind regards
Pandamütze
Message 9 of 10
(3,903 Views)
Hi Pandamütze,
you see the calculation is the smallest problem in LabView here. Most work is loading and saving the images Smiley Wink
(Don't have IMAQ installed so can't comment on that. I would have used the standard picture functions...)
Message 10 of 10
(3,896 Views)
