09-25-2007 05:49 AM
09-25-2007 05:59 AM
09-25-2007 06:06 AM
More ques...
~Sophie~ wrote:
Is there a VI that can be added on to the VI that I already use?
Is there a way to program with strings that will achieve what I want (I already do this with my Kepco power supply)?
You can search the help or the Example Finder to get the Vis you want regarding Averaging/Moving Avg [ I assume ].
There are so many ways to program with strings to achieve what you want.
It is that, first you should tell us what you need to do.
~Sophie~ wrote:
2.I seem to be having problems wiring a stop button to stop the program from running. What I need is to be able to set the Kepco power supply to 0 when the button is pressed (aborting obviously won't do this)?
Only while loops seem to have Stop buttons, and these will iterate continuously until the stop button is pressed, this is not really what I want.
Regarding this while loop, I ve answered in my previous post. A loop itself means "to iterate"; so, you CANNOT expect it NOT to iterate.
If you wish so, equate the loop count to '0' & pass the output of the '=' to the conditional terminal [Stop if True], thats it. ![]()
09-25-2007 06:52 AM - edited 09-25-2007 06:52 AM
Message Edited by GerdW on 09-25-2007 01:55 PM
