How do I use configuration files with flattened data?Hello
Hello fellow Engineers!
I would like some help and ideas from all of you.  How do I write and read data into INI files (using the configuration files functionality) when my data is in the form of flattened strings?
I await useful insights and suggestions from all of you,
With warm regards,
Aparna.
Uni,Ulm.
(2,532 Views)
Hi Aparna,
where's the problem when you use "write key"? It should autmotically change it's type to "write string key". You can set a switch to avoid any char conversions ("write raw key?").
(2,526 Views)
