How do I use Write to Spreadsheet VI
HI,
      I want to record the incomming data collected from my experiment into a spreadsheet that can be opened in excel.  I have used the Write to Spreadsheet vi but when I run the program a file is not generated.  I enter the path for the file and run the program. When I stop the program though, no file exists.
    I am using Labview 8.6 and have attatched my program.   Any suggestions would be appreciated.
(3,116 Views)
Accepted by topic author Melioris
Are you stopping the program with thefront panel Boolean? After changing that first while loop, I ran it and it created a file.
(3,102 Views)
You should also keep in mind that that VI will not generate a spreadsheet or anything related to Excel. It generates a text file that you can import into Excel.
A few comments regarding the VI:
  • Your use of local variables is unnecessary, and the End local variable is actually a race condition. Which will happen first? The reading of the local variable, or the updating of the indicator with the new value? You can't be sure. Use wires.
  • The sequence frame inside the loop (the one with the VISA functions) doesn't do anything, and can be eliminated.
  • You have sliders which have their digital displays shown, and you also have separate numeric controls. Is there a reason for this?
(3,091 Views)
I had not been stopping the program with the boolean stop.  That fixed it.  I should of thought of that before.  Thanks.
In response to the other comment:
1.  I don't need that code.  I have just not deleted it yet.
2.  I will remove the sequence frames.
3.  There is a reason for the seperate numeric controls.  I am using labview to help me control and characterize a micro air vehicle.  The sliders and the numeric controls are needed so I can test the aircrafts characteristics.
Thanks for all of your help.
(3,066 Views)
