How do I type cast an integer to an enumeration type.
When I feed an integer to the type cast icon, I do not get the corresponding enumerated type given to the type input. What am I doing wrong?
(4,970 Views)
"wwbrown" schrieb im Newsbeitrag
news:506500000008000000AF300000-1004225886000@exchange.ni.com...
> doing wrong?
you have to use the type conversion function located inside the
advanced->data manipulation palette of the block diagram. Wire your integer
from the left side and enum type from top. Now you can connect the right
output with your needed indicator or function.
Henrik
(4,968 Views)
Thanks Henrik. I was using the type cast but the real problem was a "gotcha". The input integer MUST BE THE SAME SIZE as the enum type (usually U16), for the conversion to work. I was using I32 with a U16 enum type and always getting a zero for the conversion.
W. Brown
(4,968 Views)
Right-Click on the enumerated which is wired to the "type" input and select "Representation>>U32".
Michael Aivaliotis
VI Shots LLC
(4,968 Views)
Bingo! You got it. The input integer has to be the same size as the enum type. Thanks. W. Brown
(4,968 Views)
Alternatively, rather than using a type conversion function to convert the representation of whatever is wired to the "type" input, you can convert the representation of the input X to be the same representation as the type (which for an enum is one of U32, U16, or U8).
See attachment.
(4,915 Views)
