How do I type a degrees symbol in a text string?
I want to type oC with the degrees symbol being at a superscript position. Is this possible without creating an entire new text box?
(9,783 Views)
I have no idea how to type one, but you can copy one from the character map. When you convert the string display to \codes it is \B0.
But really I have no idea how to type one.
Sorry,
Bob Young
(9,771 Views)
Under windows, switch the text indicator to '\'-codes and enter "\B0" This should give you the degree symbol for most fonts (Arial, Courier, Tahoma, Times, etc.).
(9,771 Views)
Under windows:
If you know the ASCII number of the symbol you want to use,just hold down the ALT-key and type in the ASCII-value using the numeric keypad of your keyboard.
In your case: ALT+248 (this is the ASCII-value on mine computer)
This works in all windows programs!
BJK
(9,757 Views)
Hello Kari,
on a german keyboard you will find it left from the 1 🙂
Otherwise copy and paste: "°C"
(9,750 Views)
Its work
(8,092 Views)
