How do I transfer Labview from one laptop to another?
I am using Labview2012 on my laptop to run an HP4192A LF Impedance Analyzer.  I would like to switch this capability to a different laptop. How do I do this?  Thanks!
(3,165 Views)
Hi James,
you create an executable from your VI. With this executable you create an installer. Then you install the executable using the installer on your second laptop…
(3,150 Views)
Gerd is correct if you still want to develop on your original laptop. If you want to move development to the new one, then you should install LabVIEW on the new pc. On the old one, go to the license manager and remove that license before registering LabVIEW on the new one.
(3,140 Views)
