How do I tap into "CPU" usage for a FP indicator
I have built a realy effective database cruncher...With exeptionally easy graphing functionality. The problem is the opperators will not let the dbase read / filter before they start doing the elevator button thing. I currently have the clocks set to use aprox 60~75% CPU during the read and/or filter. How do I tap into the pc cpu usage for an indicator. I think it will lower there pain if they can see that the pc is working hard.
Message Edited by MHarrington on 04-30-2007 10:12 PM
(3,248 Views)
Open your example finder and look for the example "SimpleTaskMonitor.vi". 🙂 (search for .NET)
(3,232 Views)
You can also use the ActiveX control, as discussed in this thread: http://forums.ni.com/ni/board/message?board.id=170&message.id=182535
(3,186 Views)
Hi Altenbach,
You ve taught me a good lesson.
- Partha ( CLD until Oct 2027 🙂 )
(3,164 Views)
Altenbach,
I tried to go thro' the example you had mentioned...
I cant select the .NET Constructor Node category. My system doesnt show up all those stuff.
Do I need to install .NET first to see all those Constructor categories ?
Please explain me in more detail. I cant understand this. Smiley Sad
(3,163 Views)
Parthabe,
   Yes .net is required & 1.* does not support the cpu performance function...I pulled in 3.0 but have not had a chance to test it for the cpu performance yet.
(3,157 Views)
You may want to consider the following:
  1. Disable buttons/front panel while numbers are crunching to prevent operators from doing something they shouldn't.  You may want to leave an abort button active.
  2. Use the cursor VIs to show a busy cursor.
  3. Pop up a dialog telling the user there is work going on.  A progress bar would be great, if you have the information available.  This does not have to be modal.
(3,128 Views)
