How do I split a string in a string array into separate arrays
Wire the 0 for the Arrays Subset function into the other input.
One input takes array subsets by columns, the other does it by rows.
Message 11 of 14
(2,020 Views)
Hi RavensFan,
Sorry, I don't quite understand what you mean?
Kind regards,
Message 12 of 14
(2,013 Views)
I've got it now!!
Thank you all for the help.
Message 13 of 14
(2,004 Views)
When you wire a 2D array to an Index Array, you will have 2 inputs to select the element.  If you leave the first one unwired and wire a 0 to the second, it will index by the colum (the way you want it) instead of the row (like you have now).  Look closely at the snippet I supplied earlier and you will see this.
Message 14 of 14
(2,001 Views)
