取消
显示结果
搜索替代
您的意思是:
How do I simulate sine waves up and down several triangular waveforms?
I need to simulate a number of sine waves at about 10 or 20 Hz and run these up and down a number of triangular waves. I am using the "Simulate Signal" box which generates the sine waves but am not sure what or how to connect to this to "ramp" the sinusoidal waves up and down triangular waves. The triangular waves would run at about 1 Hz.
thanks
Martin
0 项奖励
1 条消息(共 3 条)
2,802 次查看
Martin,
It seems as if you could use a second "Simulate Signal" VI, set it for a triangle pattern at your desired frequency, and then add the resulting waveform to the sine waveform. If I run that in a loop, I get a nice ramping sine wave (see attached image).
Hope it helps,
John
0 项奖励
2 条消息(共 3 条)
2,800 次查看
John,
Thanks for your help. I tried your example out today and it works fine.
Martin
0 项奖励
3 条消息(共 3 条)
2,776 次查看
