How do I simulate multiple inputs to check what the output looks like?
I am working on fixing the output of a VI I have been working on. Unfortunately, I cannot check the output unless I am streaming data. I was hoping someone could please help me figure out how to simulate a large number of signals so that I cna simply see what the output file looks like.
In terms of the output I am trying to get the data written to a file that I can open with excel with no header on the data.
(2,336 Views)
Depending on what type of signal you'd like to have input into your system you can use a simple VI such as sine.vi or you can use the Basic Function Generator.vi Both of these can generate a simple signal to be used that uses less overhead than Express VIs such as the Simulate Signal.vi
Ian M.
(2,287 Views)
