How do I setup Labview 7 to use Starteam as the CM-tool (SCC-provider) for Source Control.
I want use Starteam as the CM-tool for Source Control. Starteam is installed to be the selected SCC-provider and is working properly with other tools (ex: Visual Basic). When choosing Source Control in Labview Starteam is not in the list to be chosen.
Any ideas of solution, or if this is possible.
(2,590 Views)
I do not believe you will be successful. The SCC in LabVIEW was specifically created to work with certain products--built in scc, perforce, etc. You will probably have to use the Starteam interface to check the files in and out.
(2,590 Views)
