How do I set the VISA resource name as a constant ?
I am successfully communicating with a serial device using ModBus. The pull-down list on the front panel correctly shows COM3. I would like to remove the pull-down list and set COM3 as the default on the block diagram. Can anyone tell me how to do that please ? Many thanks,
(3,715 Views)
Accepted by topic author Placebo
Right click on that pull down list and then select change to constant...
So u can see constant name of Visa on Block diagram and no need to pull down...
pals
(3,710 Views)
Brilliant ! Works perfectly. Thank you
(3,694 Views)
