How do I set data range to a strict typdef through the control reference
Hi everyone,
I am trying to set data range to a strict typdef through the control reference, when I do so I get an "property node error".
Is there any way to set range to the strict typdef.
Vignesh
(4,215 Views)
Accepted by topic author Vignesh1987
Try setting the original (type-def) control, and not its instances.. to open the reference of original type-def control, use 'Open VI Reference'.
Edited:
These properties are not available with STRICT TYPE DEF.
a. Data Entry Limits:Increment Property
b. Data Entry Limits:Maximum Property
c. Data Entry Limits:Minimum Property
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,210 Views)
Hi Vignesh,
no, it's part of the typedef.
Use a normal "non-strict" typedef instead when you need different input ranges for several controls made with the typedef...
(4,209 Views)
Just to add a little bit to Gerd's comment.  You cannot change the properties of an instance of a strict type-def.  When you put the strict on the type def, it locks down the properties.
(4,188 Views)
I'd like to follow up on this one.
I understand the difference between a strict and regular typedef, but I was wondering why isn't there any intermediate options. For example, when using an image display control the X and Y ranges are part of the strict typedef, so you can't change them, but if you set the type to regular _EVERYTHING_ (except the data type, of course) can now be changed so you need to hand-tune every control instance for the right size and everything. Interestingly, even for a strict typedef the X and Y ranges change with different image sizes. I don't understand what's the logic behind this?
Consider an analogy: your cars has two-position knob - a) go straight, no steering at all; b) four independent steering wheels for each wheel...surely there are better ways <:
Isn't there a way around this limitation?
Lukas
(4,123 Views)
Hi Lukas,
look up the LabVIEW Idea Board, there are ideas related to your question...
(4,103 Views)
One of the more useful LV facts I learned early on was that stricts are typedefs with all properties locked. Being able to change properties of a strict means it's no longer "strict". Just my $0.02
PaulG.
Retired
(4,098 Views)
