How do I send a byte through a parallel port?
Hello, I'm trying to send a single byte of data to my device over a parallel port. How is this accomplished with labview?
(2,926 Views)
Use simply the VISA write to serial port.vi (I know, it is puzzling to use a serial vi while you intend to use a parallel port...), and connect to LPT1, instead of COM1 or other serial ports.
CC
Chilly Charly    (aka CC)
(2,914 Views)
Hi Kura,
In contradiction to Charly's reply .... I recommend to use the LabVIEW standard vi
"OUT Port.vi" from Advanced - Port I/O Palette
Have a look to the simple use of it in attached "Printer-Port-Test.vi".....
- hope you have LV7 to open this vi; if not - let me know !!
The only thing you need to do - take the standard 0x378 Address of LPT-Port and
connect a Control to "OUT Port.vi"
I think this more easy to understand.............
Regards
Werner
(2,898 Views)
