How do I scale a -5 volt input to 0-200 amps?
I have an SCB-68 with a 4-20mA signal converted to voltage with resistor to create a voltage drop. In MAX I have a VI property range set for 0-5volts on channel 7 (Referenced Single Ended). With the device off and in Test window I got 0.95Volts. With device on (no-load) I got 3.75Volts. How do I convert this back to Amps? Do I need to use custom scaling (if so how do I do that)? I am measuring large motor current 0-200 Amps. I use LabVIEW 6.1 and a 6024E PCMCIA card in a laptop.
(2,482 Views)
You don't describe your test setup beyond the SCB-68 terminal block, but it sounds like Ohm's Law to me.
V=I*R
or
I=V/R
What's the value of your resistor?
If it's 0.1 ohms (a high power shunt),
I=3.75/.1 = 37.5Amps.
(2,482 Views)
