How do I run an Access database using the system exec
I only want to start a Microsoft Access database when the operator presses a button the front panel. The operator will enter data manually and then close the Access database. I have experimented with the System Exec function, but have not been able to get it to open Access.
Any help would be appreciated,
Howard Spec
CMC Electronics
Ottawa, Canada
(2,749 Views)
Basically, I believe that pointing to the Access EXE and concatenating a space and the filename after the exe should work, but I can't test it at the moment. You may wish to post what you tried.
As a different approach, is there any reason not to access the DB from within LV?
There are several ways to do this - from NI's DB toolkit to the free LabSQL and several other free DB VIs which are floating around the web.
___________________
Try to take over the world!
(2,742 Views)
