How do I run a simulink model from labView?
Hello, I want to create a Power system (A bus system) which uses the GUI of LabView. The system itself were modelled using Matlab Simulink, and the output is from PowerGui (Load Flow Analysis). Therefore, is there a way for me to run this model from LabView?
(1,086 Views)
Accepted by topic author Rusyaidi_arif_cute
The most common method is to use the Model Interface Toolkit. See Use Simulink Model for Windows Target With LabVIEW Model Interface Toolkit
https://tmesystems.net/
(1,038 Views)
Thank you very much sir. I will do my best to learn using model interface toolkit.
(1,018 Views)
