How do I restrict multicolumn listbox to only two colums
HI
I wanted to have a Multicolumn Listbox with only 2 visible colums and no horizontal scrollbar in order to make it look like a regular listbox only with 2 columns? can I get make the column and row borders invisible?
(2,719 Views)
Righ-click on it and select "properties". On the apperance tab uncheck the vertical and horizontal scroll bars and select 2 columns and the desired number of rows.
To make the grid lines invisible, right-click and select "visible items" and uncheck horizontal and vertical lines as desired.
(On much older LabVIEW versions some of this might be different. What version do you have?)
(2,719 Views)
i totally forgot to check the visible option. That was what I wanted.
(2,719 Views)
