How do I remove the title bar from a Palm PDA front panel?
On several PDA screens, I need all the real esate I can get. The title bar chews up a lot of it.  Is there any way, in the vi settings or programmatically, that I can remove the title bar?
I've already tried the obvious step of unchecking "window has a title bar" in the window appearance catagory of the vi properties.  No apparent effect is seen.
(3,408 Views)
It sounds like you are referring to the GUI actually on your Palm devices.  I believe on Palm devices all applications have a title bar, and there isn't a way to get rid of it.  My guess is that perhaps this is a feature you can enable/disable as a Palm OS setting, or may simply be the way the Palm has defined its user interface.  If you have your Palm devices handy, check out the display settings to see any has an option to remove the title bars in general.  If you find out either way, definitely repost so the community can find the answer here as well!
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,383 Views)
I checked out the prefs on a Palm Tungsten T unit and couldn't find anything about the title bar options.  I did find, however, that if you specify blank text in the title of a form in the Palm resource editor (Palm C/C++ Development application), the title bar goes away in the compiled PDA program.
When I use a blank title in the window appearance tab of the VI properties, the title bar still shows up.
(3,375 Views)
That is interesting - I will pass this information on to R&D in the event something can be done for future versions.  Actually, it would be great if you would file a product suggestion on the matter - this goes directly to R&D and is definitely looked at!  You can file a product suggestion on-line by clicking "feedback" at:
Contact NI Page:
Best Regards,
JLS
Best,
JLS
Sixclear
(3,358 Views)
