How do I remove the "continuous run" requirement?
   I recently installed Labview 8.0 and dragged a few controls onto the front panel of a vi and connected them on the block diagram in-order to create a quick demo of a potential test setup. When I ran the "builder" to create a "exe" file the demo file has the "continuous run" button that needs to be pressed in order for the demo to run.
  How can I create a exe file that just runs by itself without the need for the user to place the vi in the continuous run state?
Dave
Kaspar
(2,989 Views)
You need to configure the top-level VI to be "run when opened".You can do this either in the VI's properties or in the build settings (override the VI's settings).
(2,973 Views)
place a while loop around the code,
(don t forget to place a timing VI, e.g. wait until next ms, or use a timed while loop)
(2,972 Views)
Dave,
Does your VI run normally in the development environment? Does it have a loop structure to keep it going? Put all the "test" controls inside a while loop. Add a Stop button connected to the termination node. Add a small delay (100-200 ms is good for user interfaces). You can also set VI Properties to "Run When Opened" which will cause the VI (or .exe) to start when opened.
Lynn
(2,970 Views)
  I have my problem fixed. Thank you for your inputs, the people who are participate in this forum are GREAT!
Kaspar
(2,951 Views)
