How do I remove LabView executables downloaded onto a Pocket PC (2003)?
I'm just testing out the process and I've downloaded a couple of versions of the tutorial executable. I'd like to know how to delete these (and future executables) so I don't clutter my pocket pc.
(2,472 Views)
Just like you delete any other file. On the file explorer click on file until you get choices to delete, copy, etc.
You will not be able to delete the file if the program is running in memory.
Dont exit the programs by clicking on the x on the window. Use the stop or exit buttons provided with the program.
Review all the programs in memory and verify that the file to be delete is not running. (There is one button on the pocket PC to see all programs running)
(2,472 Views)
Thanks for the tip El Zorro! I found I had to go into 'file explorer' then into 'start up window' then into 'programs'. From there I could delete the program, but you put me on the right path.
(2,472 Views)
