I reinstalled the Sound and Vibration toolkit and was able to fix the problem.
It seems that labview likes to change the VIs that contain incompatible block objects based on the version of labview that you are running.
I chose to save all the files which in turn corrupted the links to the help files.
Problem is fixed.
Thank you,
Dominic Lacatena
