How do I read in a column of ASCII numbers and merge in a file with 0 to 360 degrees for a polar plot?
Ronster wrote:
Raven Fan,
You must be running in another world.
That may well be true, but the option is definitely there.  Make sure you are signed in, go to your message incorrectly marked as the solution, click options,  about halfway down is "Unmark as Accepted Solution".
Message 11 of 14
(794 Views)
Darin K, I swear I was logged in and tried to perform that task no less than 10 times and that task was not in the list. After receiving you message I decided to try it one more time and it was there. I now know that I must be from another world. Ronster I have successfully populated the Polar Plot with my temperature data, but it sure isn't easy to modify the graph as far as scaling and axes lables.
Message 12 of 14
(790 Views)
Ronster,
 Sorry I haven't gotten back to you..normal work has got me buried. I took a quick look at lunch and it looks like those scales are coming from Polar Plot Demo>>Polar Plot>>Draw Polar Grids>>PG scale.vi>>Draw Scale.vi. At this point I would (starting at top level) save all the vi's under different names an modify as needed. Sorry I can't be of more help at this time as I don't have LabVIEW available to me in this office. If you get a good solution please post it.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 13 of 14
(772 Views)
GovBob,
Don't know if that last reply went through or not.  I have attached a copy of my success!  You were correct about the scaling.  I didn't bother to save it to another vi, since I couldn't stand that scaling with all of the horizontal lines across the data.  I am currently in process of adjusting the start of the plot based on the time stamp from the data.
Message 14 of 14
(765 Views)
