How do I read citadel data without LabVIEW installed?
I have a computer with the DSC module installed and is logging data into the Citadel databae on that machine. Periodically I copy the raw data over to a
separate network drive for backup. I delete the original copy to save space. I have an engineer who wants to analyze the data, but does not have LabVIEW installed on his Windows XP 64-bit machine. What is needed to allow him to view the data.
Daniel Keyser
"I reject your reality and substitute my own"
Adam Savage
"Mythbusters"
(3,331 Views)
Dan,
In order to analyze the data, they will need LabVIEW DSC Run-Time to access the Citadel 5 ODBC driver.  They will then be able to view the contents of the files through using SQL queries.
Please see the following KB: Retrieving Data from a Citadel Database Without Lookout or the LabVIEW DSC Module Installed for more information.
Jared Boothe
Staff Hardware Engineer
(3,304 Views)
Hello Jared_B,
Thank you for your response to my question. Will the DSC Run-Time install on a 64-bit OS? I could not find one that listed Windows XP Pro 64-bit.
Daniel Keyser
Adam Savage
"Mythbusters"
(3,302 Views)
Dan,
Woops!  Sorry I didn't even notice that in your first post.  Currently, National Instruments Application Software (ie - LabVIEW) is not supported on Windows XP x64.  Please see the following KB Article: Are National Instruments Products Compatible with 64-bit Windows XP x64 Operating Systems?
Jared Boothe
(3,278 Views)
Jared,
Nothing to worry about. Thank you for the information and confirmation on the Windows XP x64 not being supported.
Daniel Keyser
Adam Savage
"Mythbusters"
(3,266 Views)
