To create code from your DAQmx Global Channel, simply right-click on it and select Generate Code>>Example Code. Then if you want to display your data in another form than the one given, drop your indicators on the Front Panel, perform whatever analysis you need to on the block diagram, and finally connect the wires as needed. If you need additional assistance, please post specific questions to yield the most helpful answers from the forum.
