How do I put a scale on an image display window?
I am using a frame grabber and displaying an image. Is there any way I can put to left and bottom of the display like a axis or scale (I dont really know what to call it) that shows the pixel numbers along the x and y axis?
(3,129 Views)
As far as I know, you cannot label and image display that way.  Can you convert the data to a 2D array and use an Intensity plot?  If the image data is grayscale U8, you can even get the color scale right.
Randall Pursley
(3,123 Views)
Could you elaborate on that a little bit? What exactly is an intensity plot showing. And what do you mean in the last sentence of your post?
(3,118 Views)
The Intensity Graph is a 2D where the indices of the 2D array correspond to the X and Y positions and the element value is displayed as an intensity.  The color table used to display this intensity can be set by the user.  If your image is a grayscale image, then the pixel values are intensity values and the data can be displayed the same way in a Intensity Graph.  See attached.  You may have to find another image to use as your example.
Randall Pursley
(3,105 Views)
You can place two picture controls around your image display.
See attachment for getting started.
Andrey.
(3,099 Views)
