How do I programmatically get information about license status from the VLM
Hi
I want to make a Labview program, that can check the license status for the current user.
Is it possible to call the NI License Manger from Labview, and get the license status programmatically?
(4,887 Views)
Have you tryed using System Exec to programmatically call the NI Licence Manager executables in the command line interface?
You can find the executables at <National Instruments>\Shared\License Manager\Bin\. More information on what you could use:
NI VLM Using Command Line Interface Options
NI Volume License Manager (VLM) Usage Log Tools
Rares C.
(4,881 Views)
The Labview program shall run on the client machine (testmachine), not on the VLM server machine.
I have tried to call some of the exefiles to the local license manager [C:\Program Files (x86)\National Instruments\Shared\License Manager\Bin] with -help, but no respons.
(4,865 Views)
LabVIEW checks your licence status automatically every time you launch it.
We are on a VLM here and the server is actually at another facility two miles away from our facility.
If the link between facilities fails I can not launch LabVIEW because it says I have no valid licence.
=== Engineer Ambiguously ===
(4,843 Views)
If the link to the VLM is lost, we have 14days.
I want to use the license infomation to determine the user privileges in TestStand.
If the user have a developer license, then can the user makes changes.
If the user only have a runtime license, then can the user only execute the testsequence.
So if i can make a little labview program to get the license infomation, then can i put it in the FrontEndCallbacks in TestStand to control the user privileges.
(4,774 Views)
